how to make it posi?
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
can i just change out the spider gears in my rear to one from a posi rear and make it posi.....without any farther adjustments
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Well it is very functional! but you have to know what your doing with a welder, even then its still scary not knowing when the weld or something is going to give. Someone on here quite a while back had a welded up rear and it finally gave out and locked up and the car went into a tree, i believe everyone was ok but still, that could have killedeveryone in the car and any other people that may have got in the path of the car. Very scary...
Do it right and buy a posi or a locker, dont get yourself or anyone else killed!
Car: 1928 dodge coupe, 64 1/2 mustang
Engine: 350,289
Transmission: munice 4 speed,c4
Axle/Gears: 9" 3.00, 9" 3.25
people have been welding rearends for years it may not be the right way to do it but works great if you weld it correct while it out and clean it very good . i have ran cars, 4x4's this way and no problems. some people can't afford 300+ on a posi and if you can weld you can weld it cheap or do as i did get a mini spool
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
but I would think it is a little on the unsafe side, and could wear your tires out faster. It also may be hard on the suspension depending on how hard and how much you drive the car. The structure of these unibody cars in my opinion would not be as strong and forgiving as an older full frame car or a truck, and I would think that the two tires fighting each other for traction in turns would cause a lot of wheel hop and suspension stress.
I have never welded a rear, or used a spool, so I don't know how bad these scenarios could actually get. So I guess I am just skeptical about it.
I would have to experience driving a 3rd gen with a spool before I would think about trying it. Even then I would probably not do it.
How bad was the wheel hop on your vehicle when you used the mini-spool?
Engine: 350,289
its not real bad but car is not my daily driver mostly track drive it to shows and strip but not many shows around here maybe 1 or 2 a year and to the track almost everyweekend not right know though trying to get in my new motor and th 350 trans will be all strip now cause i gutted interior
Car: '88 IROC-Z medium orange metallic
driving it to and from the track is going to eat tires up very fast. Had a buddy with a spooled 12 bolt that rode on street tires to and from the track and switched to slicks when he got there. The street tires were bald in 1800 miles. If that's your thing then get a mini spool. Cheaper than a full spool or a diff and stronger welded spider gears.
Car: 85 berlinetta
Engine: none
Transmission: 700r4very soon t5
i put a 95 rear in my 85 your saying there is no way i can change out my gears they look the same besides longer
my 82 s10sbc has the gears welded and its a donut monster
Last edited by 85blackberlinet; Mar 30, 2006 at 06:10 PM. Reason: Automerged Doublepost
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
Yea, a daily driver would be a different story.
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
Originally Posted by '86 350
Why wouldn't I have to shim it?
Go to jegs or summit and do a search for powertrax, youll see a pick of it and understand clearer than I can impropperly type. lol!
EDIT: I may have misunderstood what you were asking. I meant that you would have to re-shim if you installed a different carrier, because the new carrier would most likely have different tolerences and this would create a different backlash than what you started with.
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
the powertrax slips in place of the spider gears, which only requires you to remove 1 bolt, slide the pin out and the spiders will fall onto your toes! Slide the powertrax unit in, slide the pin in and bolt it, put cover on, add oil and proceed to baking tires!
That specific one that you linked to is not going to work for you unless you swapped in an older rear end. Yours should be a 28 spline, the one in the ad is a 26 spline unit!
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
MAN DUDE!! take those ebay adds down!! lol!!! your going to get this thread locked!!! lol!!!
EDIT: I would stay away from the 26 spline units. They are not as strong, and 28 spline axles in the bone yards are cheap.
Oh yea, I myself wouldn't spend more than 200, maybe 250 for a decent used powertrax.
Nice. I might just pick one of these up!
My bad, I thought the ebay ad rule only applied to the buy/sell/trade section.
My car is an '86 car, wouldn't that be 26 spline?
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
Yup it would bolt right in but like I stated above 28 spline bone yard axles are cheap, in fact I might have a set you could have. Or just goto the local bone yard and get a set of axles from a 1989 to 92 F-Body and step up.
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
oops, yes it should be fine for your car '86 350' i was thinking of the original thread starters car which is a 92!
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
That means that I'd have to go with new gears though correct? I'm not to smart about rear-ends, sory if it's a lame question.
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Pull the cover and check before you order!
The powertrax unit will only go into a 'open' diff, if its already a limited slip (posi) theirs no need for the powertrax unit!
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
He said it's a limited slip car originally, not posi?
Powertrax does make units to drop into certain posi carriers, but if you have a posi and its rebuildable, then try to rebuild it first (still there will be no messing with shims as long as you do not change the gears).
Nope. Just get the 28 spline axles, and the 28 spline powertrax, and it is all a bolt-in.
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
The limited slip is wasted, it doesn't catch no matter what. I take it I'd need a new carrier if I were to get the powertrax unit correct? Then I'd have to shim it though......
EDIT: OK, I was only about 1/4 right. The only GM posi app. they have is for the Gov-Loc.
If your posi/limited slip is a clutch type vs. the cone type auburn, then it is rebuildable unless its actually broken.
Axle/Gears: 3:08
I guess i should have rephrased my question....Im looking for limited slip since my car is a daily driver...i just used the term posi as a generic term..i dont want to weld anything and have my car turn like a 747 jet... (real wide)
ive thought about a spool or something but havent done any research on them...I dont really intend to race the car but am just looking to have better traction since im planning to bolt in a rear from another car with a lower gear for the ease of it...but thanks for all the replies and feel free to continue the discussion.....thanks guys.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
novaderrik
Aug 10, 2015 12:44 PM
welder works and cheap
But different then a posi, your not gonna go around turns for ****.....
