2nd gen disk brake rear end?
Old Mar 26, 2006 | 07:29 PM
ricersniper's Avatar
i was walking thew the local u-pull-it yard the other day and saw a very nice late 70's camaro setting up on blocks. the first thing i noticed was that it had rear disk breaks on it. i know the scarsity of 3rd gen rear disk set ups and wonderd if the 2nd gen is a good match or an easy swap into my 86 iroc. i know there are some issues with the 7.5 rears in my car. what size is the late 70's rear end and are they any stronger than my 7.5? is it worth the work?
Old Mar 26, 2006 | 07:41 PM
No it is not an easy swap. It has a leaf-spring setup; these cars have coil springs with lower control arms and a torque arm that bolts to the center section on a set of bolt holes that the 2nd gen doesn't have.
Yes it's stronger.
The disk brakes on the 2nd gen are the same old cast-iron Saginaw system that sucks so bad on the early ones of these cars, not worth swapping in. If you really want disk brakes, get the rare out of a 90-92; with the aluminum PBR calipers. They are VASTLY superior.
Old Mar 26, 2006 | 07:42 PM
thank you very much
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
AkDrifted
Aug 17, 2015 07:45 PM
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
