Flywheel thickness?
Old Mar 30, 2006 | 07:36 AM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
Flywheel thickness?
I just tried to install my spec stage 3 for my T-56 conversion and it hits the flywheel bolts. It seems as though the clutch is too deep. This means one of three things: I'm trying to put it on backwards, it's the wrong clutch, or it's the wrong flywheel.
I looked up the number and it’s the right clutch kit (SC423 – 93-97 lt1 camaro). I’m pretty sure that it’s installed the right way (the side that says FW Side was installed facing the flywheel) and pictures/instructions on their site verify this. The flywheel was machined down at least once, I know because I had it done. It’s possible that it was machined down before.
What’s the flywheel spec thickness and how do I measure it?
Additional question: is the lt1 flywheel the same as the flywheel for the 305/350? After some more poking around I'm starting to think they're different.
Old Mar 30, 2006 | 12:13 PM
Gummie's Avatar
Car: 88 GTA
Just bougt a lt1 style centerforce. 700177 if anyone wants to look up the part and see it for themselves.
Old Mar 30, 2006 | 12:37 PM
dr1's Avatar
dr1
Car: '89 Firebird Formula
Engine: 305 TBI
put something flat across the flywheel, like a ruler, while its bolted up and see if it hits the flywheel bolts
Old Mar 30, 2006 | 12:39 PM
What flywheel do you have?
No, the T-56 flywheel is not the same as the ones used with the T-5. It is unique. If you don't have a specifically T-56 flywheel, you'll need to get one.
Old Mar 30, 2006 | 09:27 PM
Gummie's Avatar
Car: 88 GTA
I've got a T-5 wheel. The T-56 wheel is on the way. I'm almost ashamed to think about how much this thing cost me...
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
el_muerte
Sep 16, 2015 12:01 AM
