"aftermarket" T56 vs. 4th gen comparison?
Old Mar 31, 2006 | 10:26 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Eventually I'll put a T56 into the IROC. Right now I have a T5.
My 2 choices are to do the usual 4th gen swap, or to buy the aftermarket Tremec unit which will use most of my existing hardware. Do any of the guys here that went that route have any comments about that choice?
It seems appealing to me because I can keep my stock mechanical speedometer, along with all the T5 hardware including the flywheel and clutch.
By the time I spend the money for the mechanical speedo "upgrade" on a 4th gen T56, buy a flywheel and buy a new clutch, it seems like my expenses will be higher than just buying the new aftermarket T56.
Comments? Anybody else weigh these same issues? What was your decision?
Old Mar 31, 2006 | 11:36 AM
b's90cam's Avatar
Car: 98 z28
Engine: ls1
Transmission: t56
Axle/Gears: soon to be 3.73's
i was going to swap out my t-5 for a t56. I was told that by the time you buy all the things you need for the lt1 t-56 to work, you're up to the price of the aftermarket. On the aftermarket one the crossmember work, the clutch works, just need to shorten the driveshaft and possibly the torque arm. I would go aftermarket.
Old Mar 31, 2006 | 12:42 PM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
The LS1 4thgen trans, '98 and up will use all your hardware in clutch forms with the 8-207 bellhousing from mcleod, and the 8617 pilot bearing.
Not sure about the crossmember stuff yet. Everything is ready to slide the trans in today in my swap. Time to go he-man.
19irocz85
Aug 31, 2015 10:31 PM
19irocz85
Aug 30, 2015 10:03 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
