torque converter too "tight?"'
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
Is it possible for the torque converter to be too tight in my car? I put a factory replacement 86 TPI converter behind my LT1 and I have to press hard on the brakes to keep the car stopped. It only idles at 850 RPM's but the car is lurching forward unless I have the brake fully depressed. I was wondering if going with maybe a 2200-2400 stall would fix this probem?
Moderator/TGO Supporter
Car: 87 IROC 92 Z-28 91 Ragtop
Engine: 5.7
Transmission: 700-r4
Lowering the idle speed to the recommended level will reduce the forward creep, but it will still be there to some extent. Installing a converter with a higher stall ratio will reduce the creep. We recently installed a Pro-Built 700-R4 and Edge 9.5-inch 2600 stall converter in our '92 5.7. At idle the car does not creep, slightly up say 900 rpm the car does creep. It does take more throttle compared to the stock 12-inch converter to accelerate the car, but not a lot, and oddly, the cruising RPM on the highway is less than before the new parts were installed. At WOT, the car is much faster. Gas mileage is the same or better than before. Eventually, when I swap the stock converter in my '87 IROC 5.7, it will be an Edge 9.5, but due to my need to drive through lots of city stop-and-go traffic, will probably choose a 2200 stall ratio.
Ragtop Man
Sep 12, 2015 12:23 AM
