2nd gear grind
Old Apr 8, 2006 | 03:11 PM
niceroc's Avatar
Car: 87 iroc
Engine: 454 .030 over
Transmission: th-350
Axle/Gears: 9 bolt
2nd gear grind
ok i know it isnt a thirdgen but my firnd just got a twin turbo dodge strealth.. 95... he hadf it for liek 3 weeks then i was in the car he went to do a good 1-2 shifty and it ground into gear... ground everytime after that... anybody got any idea what it could be? if it was a syncro did just the shift do it or was it kinda like a time bomb goin off and it happened to happen right then?
Old Apr 8, 2006 | 03:42 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Im not a big brainer when it comes to the sticks but my guess would be a synchro gone.
BTW this thread isnt going to last long!
Old Apr 8, 2006 | 10:57 PM
1985Irok's Avatar
Car: 1985 IROC
Axle/Gears: factory
Yea, that sounds like a bad synchro to me. A couple of my gears do that from time to time. I don't know how much you know about synchros, but basically, a synchro is made of a hub and a sleeve. The sleeve slides across the hub and the sleeve is what engages the next gear. It gets a little more complicated, but there are a few other parts to the synchro that help the sleeve slide onto the next gear smoothly. When the synchro's bad it cant engage the gear easily so there's clashing as you are now forcing it into gear. Not sure about his transmission, but I think rebuild kits for T-5's run about $400. That includes new synchros, bearings, locking pins, and such.
db057
Apr 28, 2019 07:45 AM
Jorlain
Oct 8, 2015 01:57 AM
88rscamar0
Sep 23, 2015 09:08 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
