Stock Rearend Ratio??
Old Apr 12, 2006 | 09:01 PM
BAdata1's Avatar
Just wondering if anyone could tell me the stock rear end ratio on my 89 Trans am GTA 350 auto??? Thanks!!
Old Apr 12, 2006 | 10:27 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
either look up the RPO code or count the number of ring gear teeth and divide that by the number of pinion gear teeth.
Old Apr 12, 2006 | 10:33 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
RPO code will be the way to tell you what the car rolled out of the facory with 18 years ago, only way to tell whats actually in there right now is to pull the cover and count teeth.
Old Apr 14, 2006 | 01:59 PM
w1964bgta's Avatar
Car: 89 gta ws6, Dodge Turbo Diesel, H-D
Engine: 383 4-bolt #638 block
Transmission: 700r4, corvette servo, 2200 stall
Axle/Gears: 3.27 9 bolt b-w, pbr discs
You should have a 3.27 borg warner but the rpo is the way to go
or as 1981Lt1 said pull the cover and start counting.
Check the RPO list located under the console lid for these Codes:
GH3 = 2:77 BW rear axle ratio
GW6= 3:27 BW rear axle ratio
G80= Limited slip rear
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Genopsyde
Oct 7, 2015 08:35 PM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
happyhapka
Aug 15, 2015 04:42 PM
