TKO speedo cable
Old Apr 13, 2006 | 11:38 PM
FullSendRacing's Avatar
Car: '85 Trans Am FAILBIRD
Axle/Gears: 4th gen torsen 3.42
TKO speedo cable
I see that Forte makes a converter so you can use a normal GM f-body speedo cable. Seems like the right way to do it but 60 bucks is pretty steep for this little thing. Are there any other options?
I happen to have a speedo cable that fits the TKO, but the other end is a screw-on style, and the thing isn't nearly long enough to reach up in behind the dash. Don't know what good it is to me unless there's something out there to go from this screw-on style to a GM clip-on to go into the gauge.
Old Apr 14, 2006 | 08:09 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
I'm not understanding your problem. my stock cable screwed right up to my TKO600.....
Old Apr 15, 2006 | 09:40 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Forte is the only one that makes the mechanical adapter. If you have the stock speedo, a cable for an 87 Camaro will work. The other option is to get a aftermarket electronic speedo & use the electronic speed sensor that comes with the TKO. Although that would cost more than $60.
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
