late 87 700r4 build content
Old Apr 14, 2006 | 02:21 PM
bobdole369's Avatar
Car: 1989 Firebird
Engine: 2.8L V6 MPFI
Transmission: Beat to heck 700R4
Hows this look for a purchase list? 87 700r4 on my V6 - daily driver. Am I doubling up on anything or is anything obvious missing?
74006B Master kit, 700R4 L1987-UP
B74020A Band 700-R4 / 4L60E 1985-UP 2 tangs
74030E Bushing kit, 700-R4 / 4L60E L1984-UP
74175T Ring kit , 700R4 / 4L60E
74201A Bearing kit, 700R4 / 4L60E
74200 Thrust washer kit, 700R4 / 4L60E
74010 Filter, 700-R4 1982-93 Wide filter
74300F Pan Gasket: 700R4 / 4L60E (says fiber, I figured cork would come with the master kit above, don't want cork anything)
T74165B Pump Ring Kit, 700R4/4L60E NoYoYo, TRANSGO, 1982-Up, 700PK
A64533 Pump Vanes, 125 / 700R4 / 4L60E / 2004R x10
T74908 Servo extendo pins 700R4 / 4L60E (my apply pin is 0.025 too short)
A74926E Accumulator SPRING, 1-2 , 700 / 4L60E, (GREEN)
A74936H Accumulator SPRING, 1-2 & 3-4, 700 / 4L60E Performance 1984-93
A74927 Accumulator Piston, 700R4 / 4L60E, 1-2 & 3-4 x2
A74507B Pressure Regulator Valve, w / 2 Flats , 700-R4
74178AT RING,700-R4/4L60E TURBINE SFT x10 (figured I'd mess up a bunch of these on install)
Total: $202.34
Old Apr 14, 2006 | 05:27 PM
greggbruce's Avatar
Car: 84 454 monte, 89 formula, 86 camaro
Engine: the bigger the better
Transmission: 700/4L60 in everything
Axle/Gears: wish they were all 4.10's or better
torque converter????
and don't forget to flush the cooler......
you got it apart already??
do you need any hard parts??
when you replace the servo pin, put a new spring on it. the old ones squish usually.
sometimes they come in the overhaul kit.
and how do you know the pin is too short??
Old Apr 14, 2006 | 10:21 PM
bobdole369's Avatar
Car: 1989 Firebird
Ah yes, torque converter is already here. Its all apart and I don't believe I need any hard parts (at least not yet.) I'll look into a spring for the servo pin, which is too short according to the ATSG book. (I measured the pin).
I'll have to look into a flush kit for the cooler... thanks for the reminder.
Old Apr 15, 2006 | 07:36 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
The problem with the servo pin extender is that it extends the pin a bunch. Then you must grind it down to fit. The only way to know exactly what is correct is to use the gm servo pin tool. This is a $400 item not easily found. I would buy a new GM pin and avoid the extender. When servo is reassembled, push the cap in and out with your palm. Approx 1/8 inch of travel is typical
Hotrodboba400
Dec 10, 2019 07:07 PM
TheTraut88
Sep 7, 2015 05:22 PM
Street Lethal
Sep 7, 2015 01:09 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
