Stock Rear End
Old Apr 23, 2006 | 07:37 PM
david_351's Avatar
Stock Rear End
Hey guys im new to the board, I have owned to Trans Ams in the past, and 83 and an 84 Recaro Trans Am. Both cars were great and got me hooked on F-bodys. Now after a few years after driving econoboxes im in a position where I can afford to build up the f car Ive always wanted. Anyways im looking at purchasing an 85-92 Camaro or Trans Am, and wan't to know how much power the stock rear end will put up with. Im planning on building either a supercharged LT1 or perhaps a Twin Turbo L98 and using a T56 transmission. I already aquired the T56, however I need to know how much power and tourque I can put threw the stock rear end. Would 550RWHP be too much? if so what would you recommend for a good repacement rear? a ford 9"?
Old Apr 23, 2006 | 11:25 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
if it see's one set of stickys and a good clutch dump its over. 10 bolts are most comon and are a dime a dozen however they wont handle all that hp stock. Go bigger for that amount of hp. If your dumping 10k into a motor might as well dump a few g's into the rear. Power is nothing if it cant get to the ground.
Old Apr 25, 2006 | 11:54 AM
drag1LE's Avatar
Car: 1991 Camaro 1LE Z28
Engine: 6.0L
Axle/Gears: Ford 9" 4.33
Right. Ten bolts are useless. Most likely break an axle (I broke the stock one, and a supposedly "stronger" Moser replacement axle). More wise to just go with a 9".
Moser makes a 9" for 3rd gen. That's what I have now, and it's worked great. If you do go that route, you may want to think about pitching the stock torque arm (in a 5 spd, the piece that goes from the transmission to the rear end). Jeg's makes an aftermarket piece that attaches to the floor (tunnel) instead of the transmission. You'll hook like a banshee.
Old Apr 25, 2006 | 12:13 PM
izcain's Avatar
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
the stock rearend works perfectly for just what gm designed it for.... stock applications lol. The minute a lil to much traction hits with some real power and it will be all done.
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
BlackBoulder
Aug 11, 2015 11:15 PM
