Need some help on the rear end.
Old Apr 24, 2006 | 06:45 PM
RandyZ's Avatar
Car: 1983 & 1993 camaro z28
Engine: 5.0 carbed/ LT1 injected
Transmission: T5/auto
Axle/Gears: 373/posi
has anyone easle tryed to put a rear end out of another car besides a camaro and had look.Like a monte rear end .Yes i know the touge arm does fit it.
Old Apr 24, 2006 | 08:56 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
I think you mean doesn't fit it. The Camaro rear is unique to Camaros and Firebirds. Any other rear is going to require fabrication to fit in the car.
Old Apr 24, 2006 | 09:07 PM
RandyZ's Avatar
Well ill the 4th gen rear end fit my 88 camaro.
Old Apr 24, 2006 | 09:14 PM
its scot's Avatar
Car: 85 iroc-z
Engine: blown 350
Axle/Gears: 4.10
I just installed a 12 bolt out of a 1970 chevelle fabricated all the brakets it was a lot of work but the length is corect (aprox. 1/4 inch shorter) but I saved about $1200 over an aftermarket rear!
Yes, but it's 3" wider, meaning that without 4th gen backspacing on your wheels the tires will stick past the wheel lips by 1.5" per side. Rather ugly and illegal in many states. Plus, what's the real advantage? The 4th gen rear isn't any stronger than a good 3rd gen rear (one with 28 spline axels).
If you want strength you want a bolt in 12-bolt or 9". Alternately you could upgrade your exisitng rear (assuming it's a 7.5 or 7.625" 10-bolt) with better gears, a limited slip, and better axels.
Old Apr 24, 2006 | 09:29 PM
RandyZ's Avatar
humm
Was offered a 9 bolt posi 342 or sothing like that
Old Apr 24, 2006 | 09:31 PM
I'd take it. 9-bolts are tough rears nd hard to find, especially if it's got discs. Parts are harder to come by, but Randy's has gears and bearings.
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
