V6/V8 T5 Torque arm mounts
Old Apr 29, 2006 | 09:33 PM
Pat Hall's Avatar
Nobody seems to be able to answer this question for sure. Are the V6 and V8 T5 torque arm mounts the same? Even if they're not exactly the same, can either of them work on either trans? I need one for a V8 WC T5 trans, and there's a 90 V6 5 speed RS sitting in the boneyard with a perfect mount I can get for dirt cheap. Any help on this would be appreciated. Thanks.
Old Apr 29, 2006 | 09:40 PM
82Z28's Avatar
i went through this it depends on year primarly...the V6 can be different from a V8...it depends on the tail shaft and the torque arm direction(which you can use a energy suspension bushing and rotate it to solve)...wish i could be more helpfull but i had a problem when i installed a v6 5 speed in my camaro...this is just my hope its helpfull
Old Apr 30, 2006 | 03:58 PM
Not Danny's Avatar
Car: 83 z28
Engine: 305 for now
Transmission: 5 speed
it worked ok for me when i put a 85 v6 t5 into my 83 z. bolted up with no problems on the torque arm.
Camarothatcould
Apr 10, 2007 06:36 AM
