Final order. I need advice
Old Apr 9, 2007 | 09:16 PM
Camarothatcould's Avatar
Car: IROC/F250 7.3
Engine: LS12367
Transmission: Autos
I am making a huge purchase tonight of parts to complete my build. I need help to pick out pushrods though. I am running a flat tappet setup along with Vortec heads. I know flat tappet pushrods are longer than roller, but what is the length I need?
Here are all the parts I am ordering FYI...
Part # Item Price Qty Line Total Delete
ARP-134-7101 Rocker Arm Studs, High Performance, 3/8-24 in. Thread, 1.75 in. Effective Stud Length, Chevy, Small Block, Kit $35.95 $35.95
CCA-153 Assembly Lubricant, for Camshaft Break-In, 8 fluid oz., Each $9.99 $9.99
·The part is classified hazardous. If you purchase this part, your order can only be shipped by ground.
CCA-611-16 Valve Locks, Machined, Hardened Steel, 10 Degree, 1-Groove, 11/32 in. Valve Stem, Set of 16 $22.88 $22.88
CCA-740-16 Valve Spring Retainers, Steel, 10 Degree, 1.500 in. Outside Diameter, .690 in. Inside Diameter, Set of 16 $56.95 $56.95
CCA-987-16 Valve Springs, Dual, 1.430 in. Outside Diameter, 344 lbs./in. Rate, 1.150 in. Coil Bind Height, Set of 16 $87.88 $87.88
CCA-CL12-250-3 Cam and Lifters, Hydraulic Flat Tappet, Advertised Duration 284/296, Lift .507/.510, Chevy, Small Block, Kit $179.95 $179.95
FEL-KS2600 Gaskets, Full Set, Chevy, Small Block Gen I, 4.3/4.6/5.0/5.4/5.7L, Set $39.95 $39.95
HLY-12-804 Fuel Pressure Regulator, Chrome Plated, 1-4 psi, Universal, Each $26.95 $26.95
HLY-20-95 Throttle Cable Bracket, Steel, Gold Iridited, Chevy, Big/Small Block, Holley, 4150/4160, Each $19.88 $19.88
SUM-G1573HS Bolts, Intake Manifold, Stainless Steel, Natural, Hex Head, Chevy, Small Block, Kit $8.95 $8.95
SUM-G6600 Timing Chain and Gear Set, True Roller, Double Roller, Steel Sprockets, Chevy, V6/V8 Small Block, Set $31.95 $31.95
Old Apr 9, 2007 | 09:55 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
Re: Final order. I need advise
Get the ones that say standard length 5/16"
Old Apr 9, 2007 | 10:01 PM
Car: IROC/F250 7.3
Engine: LS12367
Transmission: Autos
I cant find any that just say "Standard". they just have a length measurement
Old Apr 9, 2007 | 11:33 PM
Car: IROC/F250 7.3
Engine: LS12367
Transmission: Autos
7.794. Got it now. Order has been processed. Thank you
Old Apr 10, 2007 | 12:11 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
hmm, too bad, I was going to say:
skip the cam lube, it comes in the box with your cam.
don't get hex head bolts for your intake manifold, remember how hard it was to get a socket on those? Use allen bolts instead.
and the comp double roller timing chain is exactly $1 more than the summit brand one. I liked the comp sticker so...
You already have the vortec intake manifold I take it?
Old Apr 10, 2007 | 06:36 AM
Car: IROC/F250 7.3
Engine: LS12367
Transmission: Autos
Yea, I have the intake already. Guess I can use that cam lube on other things? Like the pushrods and stuff?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Antips16
Oct 30, 2015 06:42 PM
Randomtask2
Sep 10, 2015 08:37 AM
IROCZ1989
Sep 4, 2015 11:54 AM
mrdevontay
Sep 2, 2015 08:04 PM
