V6 V8 T5
Old Apr 30, 2006 | 05:04 PM
redcattaro's Avatar
Car: '84 Z28, '86 IROC
Engine: 305, 406
Transmission: T5, Super T10
Axle/Gears: 3.23, 4.10 Posi
V6 V8 T5
What is the difference between a t5 from say a 94 3.4l v6 and a t5 from a v8 car? can v6 t5 be bolted to v8 bellhousing?
Old Apr 30, 2006 | 08:04 PM
Brettlinetta's Avatar
Car: 85' Berlinetta
Engine: Twin Turbo 350 coming soon
Transmission: TH350
Axle/Gears: 10 bolt 3.42 posi
The V6 T-5 will have a different Input shaft on it, to match the V6 output shaft. Read a swap article, and it will detail the parts you need. The input shaft can be swapped fairly easily on these units
_bR3T7
Old May 1, 2006 | 05:29 PM
redcattaro's Avatar
Engine: 305, 406
is it worth all that trouble or should i just keep looking for a v8 t5?
Old May 2, 2006 | 06:38 PM
qytum's Avatar
Car: 92 Formula
Engine: 5.0L TBI
Axle/Gears: 3.73 posi
A thirdgen v6 T5 can be made to work easily by grindind down the input shaft and using a v6 clutch disc. However the v6 ratios will get on your nerves sooner or later. Also from what I have been able to find, the 4th gen T5 does not bolt to the thirdgen v8 bellhousing.
If you want to go with a thirdgen v6 t5 you can read the tech article in my sig. But I would recommend saving and finding a v8 T5 just so you have the better ratios.
