T5 Swap
Car: 91 Camaro RS
Engine: 305 TBI
T5 Swap
Alright
i have everything i need for the swap
into my 89 bird
what all must i do to get the pedals in? i should just be able to drill a hole and bolt them right?
and will i have speedo problems??
anybody else have any complications with going from a 700R4 to a T5?
into my 89 bird
No, all the holes you need for the pedals, are already there. They attach to the same hardware that holds in the auto pedals.
You will not have speedo problems if you get the right VSS and speedo gears for your rear end, and install them properly. Not too tough really.
About the most nearly difficult thing is to cut the hole where the clutch master cyl mounts. But if you have the new cyl, with its gasket, use that as a template. Piece of cake. Next toughest thing is the shifter hole.
Hello, Michael
Aug 20, 2015 03:19 PM
