borg t-5 oil change to syntec???
Old May 6, 2006 | 11:27 AM
FOX-GTA_89's Avatar
Car: GTA WS-6 1989 fully loaded
Engine: 1995 9C1 LT1 police pak XE cam
Transmission: t-5 borg warner
is it true that the transmission has to be tear apart and cleen very well to charge to syntetic oil?? heard atf and syntec are not compatible..true???
i already bought my Royal purple Syncromax oil....its written on bottle...for manual transmission that require automatic fluid....can i just fill it out...and about the heigh of fluid...the transmission when its bolted to bell housing is not straight...soo do i need to overfill a bit??
Old May 6, 2006 | 12:37 PM
No. Not true.
You can't believe any more than about .0000001% of whatever you've "heard" about lubricants. It's just amazing beyond almost any other subject, how much witchcraft and vodoo and black magic gets invoked when people start giving their opinions (never backed up by any facts) about oil. About the only other thing that even comes close is electricity. In the case of a manual transmission, you've got some steel parts spinning around, on some roller bearings. This is not something supernatural that requires wizards and sages to decipher.
Use it, it will be perfectly fine.
No you do not need to overfill anything. Take the drain plug out, let it empty, put the drain plug back in, take out the fill plug, fill to that level. Don't worry about "tilted", just fill it until it reaches the plug, and put the plug back in.
Both plugs are on the pass side of the trans. DO NOT remove the thing that looks somewhat like a plug on the driver's side!!! Disaster will result.
eightsixseven
Dec 16, 2024 01:50 PM
Cacike
Aug 27, 2015 05:10 PM
Navy8125
Aug 21, 2015 09:32 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
