help me please, cant get t56 off from engine
Old May 11, 2006 | 11:38 PM
CAMAROJOKESTER's Avatar
Car: CAMARO
Engine: 383 LT1
Transmission: T 56
hey. i cant get the tranny off of the engine, i see that the fork is holding it on but how do i get it off. i cant get a socket or wrench on it, and i was told it will slide off, i cant get it. also its out of the car.. please help..
Old May 12, 2006 | 06:11 AM
You need to take off the 2 nuts that hold on the slave cyl. That will let the fork come out of the throwout.
Then the 6 bolts that hold the bell housing to the motor.
Don't be standing underneath it when you take the 6th one out, because it WILL fall off.
I can't begin to imagine what hardware you could possibly be working on, that you can't get a tool onto. That sounds like you're working on the wrong thing.
Old May 15, 2006 | 01:44 PM
Car: CAMARO
Engine: 383 LT1
Transmission: T 56
so i guess i have to rebolt everything up, then just pull the fork out..
Old May 15, 2006 | 02:02 PM
1BADROC's Avatar
Car: 1989 IROC-Z
Axle/Gears: 9bolt 3.27
ok this is what you do unbolt the tranny from the bell undo the 2 small bolts that hold on the slave first. you will be able to side it off and to the side. you can see the clutch fork then. If you have the tranny part way out slide it back in as far as you can dont worry about bolts. pull the clutch fork back jiggle and it will pop off the throwout bearing. then the tranny will slide out with ease. then undo the bellhousing from the engine. then take off the clutch loosen each bolt little by little in a circular or crisscross pattern dont take one out then the other do them all the same. then the flywheel. buy a 93 through 95 4thgen starter. The bell wont fit over your stock. i just finished this 2 weeks ago.
Old May 15, 2006 | 02:15 PM
1BADROC's Avatar
Car: 1989 IROC-Z
dont do what sofakingdom said it is much easier to take the trans off the bellhousing then you can sit up under the car and take the bell off with ease and it goes back together the same on the other car very easily with the bell on it just makes it harder.
Old May 15, 2006 | 02:17 PM
Car: CAMARO
Engine: 383 LT1
Transmission: T 56
thanks.. i had it in my camaro i am swaping engines and pulled it all out.. i have the tranny completely unbolted and i couldnt get it off b/c of the fork.. now i know.. thanks..
BlackphantomZ28
Aug 31, 2015 10:29 AM
jharrison5
Aug 19, 2015 05:53 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
