differential difference
Old May 14, 2006 | 07:35 AM
fbomb's Avatar
Car: 87 formula ws6
Engine: mild 400sbc
Transmission: rebuilt 700r4 shift kit, 2400 stall
Axle/Gears: 4.10 open diff
what is the difference from the ten and nine bolt rearends, i just bought a 3.23 10 bolt posi from someone and now i have a chance at a 9 bolt from an 86 t/a, i'm wondering if it's worth trying to pick up or not and what the difference is between the two??
Old May 14, 2006 | 07:46 AM
TundPortZ's Avatar
9 bolt rear ends are kind of the odd ball rear ends put in these cars, they are stronger than a stock 10 bolt, but its damn near impossible to find different gear ratios for them. I would personally steer clear of the 9 bolt. Even though 10 bolts are not exactly known for their durability.
Old May 14, 2006 | 08:03 AM
Z28cross-fire's Avatar
Car: '94 Z28
Engine: LT1 350
Transmission: 4L60E/A4
9 bolt
Has a 7.75" ring gear diameter. Also comes in different sized gear ratios like 2.77, 3.27, 3.45, and such. Very hard to find parts for. Very expensive to fix, since there are no parts for them anymore.
10 bolt
7.5", or 7.625" ring gear diameter. A little weaker, yet easier to find parts for, and cheaper to fix. Has gear ratios like 2.73, 3.23, 3.42 and such.
Old May 16, 2006 | 01:02 PM
fbomb's Avatar
Car: 87 formula ws6
Engine: mild 400sbc
well thats good to know, this one would be needing a rebuild anyway, so i'll forget about it. thanks guys
Old May 16, 2006 | 01:17 PM
1BADROC's Avatar
Car: 1989 IROC-Z
Axle/Gears: 9bolt 3.27
look on this site some there is a site where you can get rebuild kits and gears for them. I have 2 9-bolts they are great rearends if you get some power out of your car and run slicks you will destroy a 10bolt.
dbrochard
Jan 28, 2016 08:42 AM
dbrochard
Sep 19, 2015 08:13 PM
georgiaslim45
Sep 9, 2015 08:12 PM
georgiaslim45
Sep 9, 2015 08:11 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
