T-5 Swap firewall cutting tool?
Old May 16, 2006 | 03:53 PM
Ant's Avatar
Ant
Car: 1989 Iroc-z 1994 Z28 LT1
Engine: 5.7 Liter L98 Tuned Port Injection 5.7 LT1
Transmission: 700R4 and 4L60E
What tool did you guys use to cut the hole in the firewall for the clutch hydraulic assembly. I have the templet in my carpet and the the hole cant just be drilled out?
Old May 16, 2006 | 04:00 PM
A hole saw or a dragout would be best; followed by a rotary file or the like (since the hole isn't supposed to be quite exactly round...)
Old May 16, 2006 | 04:22 PM
1BADROC's Avatar
Car: 1989 IROC-Z
Axle/Gears: 9bolt 3.27
i hope your hole in carpet hasnt shifted over the years or you hole will be in wrong place. I had the parts 95 T/A in the driveway when i did the t-56 swap i took a piece of flexible cardboard used the brake booster holes as a reference to make sure i put it in the right spot on the 3rd gen since they are the same. i used a drill to get rid of the center just drill holes around the edge. then poke it out. take a little grinder it wont grind the metal it will melt it away and leave a nice smooth hole.
Jeremys87
Jul 14, 2022 09:08 PM
customblackbird
Aug 15, 2021 10:16 PM
Dkelz313
Apr 7, 2016 10:38 PM
gta90
Sep 15, 2015 04:00 PM
Dialed_In
Aug 20, 2015 01:45 PM
