t56 question...
Old May 18, 2006 | 05:22 PM
rocc4u's Avatar
Car: 1992 Z28
Engine: 383 Miniram
t56 question...
For you that have done the swap, what will happen if the dakota digital box for the vms is not in and you drive it? I just did an engine and tranny swap but I have not put the box in yet. I drove around the block and Im getting alot of surging from the cam, I think. I dont know if the dakota box will make the car act like that too.
Old May 19, 2006 | 03:12 AM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
the box is for the electronic signal for the computer, i.e., no computer no need to have a signal. Since the T56 has an electronic output speed signal, the only problem I can see is the speedo won't work for now.
Old May 19, 2006 | 08:39 AM
rocc4u's Avatar
Car: 1992 Z28
Engine: 383 Miniram
I do have the computer but if it just jacks up the speedo then I will get the digital box later. I just didnt know if it might cause the car to run like $hit.
Your down in SA? My cousin lives down there off Judson street. I get down there every now and then. Any good speed shops there?
Old May 19, 2006 | 03:14 PM
Br1dgeman's Avatar
Car: Depends on what day it is..
Engine: Um, Chevy small-block
Transmission: One that shifts
Axle/Gears: Got those too...
Chances are the ECM will eventually through a VSS trouble code. Obviously, it will not know vehicle speed, which might cause it to act a bit quirky, even though it will know engine load (MAP or MAF) and throttle position. That may be why the car is acting funny...
Old May 19, 2006 | 05:10 PM
1981LT1's Avatar
Engine: LT1; LT1
True, the computer needs the vss input for proper calibration.
What a spooky coincidence, I live off of Judson too!
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bigjay89gta
Oct 15, 2015 08:04 AM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
Vincent135
Sep 28, 2015 10:50 PM
