Strange 12 Bolt - Fluid??
I have a Strange 12 bolt rear with their "super strength" posi unit. What weight oil should I use and what kind of posi additive? Any brand recommendations? Thanks.
Car: 1987 GTA/1998 Explorer
Engine: 355, trick flow heads, zz409 cam, 3
Transmission: 700r4, shift kit, valve body
Axle/Gears: precision 3.73's, auburn diff
just curious, how much did that rear set you back with that posi unit, and what axles did you get? im about to buy basically the same thing. is the super strength unit necessarily for a street car under 500 HP or is it more of a drag unit?
I bought the rear end a couple years ago, so I don't really remember. I think the whole thing was around 2 grand, and I know the super strength posi was around 200. I believe the axles were 33 spline. The stronger posi probably isn't necessary for under 500 HP, but I'm between 400-450 and I got it anyways just to be safe.
Car: 1986 Camaro Berlinetta
Engine: 406 roller
Transmission: th 350
Axle/Gears: 4.10
the guy who put my 12 bolt together recommend i use 91/40 semi synthetic in it. but ive got a full spool. im not sure if its different with a posi unit?
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
I have the same rear with the super strength posi and I run the AmsOil heavier weight. It has the friction additive built into it.
The rear set me back about 2300 about 5 years ago. That was with the upgraded posi, 4.11 gears and 33 spline axles.
Hope that helps
Hope that helps
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
someone972
Aug 30, 2015 12:52 AM
red90IROCls1
Aug 25, 2015 06:56 AM
