Automatic Axle Ratio?
Old May 22, 2006 | 05:54 PM
nomad88z's Avatar
Is there a reason why the factory puts in tall gears for automatics?
If not, can I put in a 3.42 axle ratio in my '88 Iroc-Z 350 700R4?
Old May 22, 2006 | 06:29 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You can put whatever gear ratio you want in your car. Just recalibrate the speedo.
The 700R4 didn't really get what you would call a performance gear ratio in the diff unless it was an underpowered V6. The torque of a 350 through the low first gear of the 700R4 can easy spin the tires if the ratio is too high. 3.27 was a performance ratio for the 350 but more common is the 2.77. That way you can still get a deep gear multiplication through the 700R4's 3.06 first gear and then get low engine rpms while cruising down the highway in OD.
My truck has a 4L80E tranny. Same gear ratios as a TH400 but also has an OD. The 28" tall tires are powered by 4.10 gears in the diff. At 60 mph, engine rpms are around 2800.
InfernalVortex
Apr 20, 2021 11:31 AM
Lbibb
May 5, 2016 12:00 AM
loud91rs
Oct 5, 2015 10:05 PM
bjpotter
Oct 4, 2015 07:48 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
