TPI to carb
Old May 24, 2006 | 10:53 PM
70gmc's Avatar
Car: 1970 GMC LWB Street strip
Engine: 383 stroker
Transmission: 350TH
Axle/Gears: 12 Bolt 4:11
TPI to carb
If i switched from TPI to carb in a 88 Iroc and elminated the computer. what do i have to do to get the lockup converter to function properly. Thanks
Old May 31, 2006 | 10:42 PM
madhatter's Avatar
im now just stumbling across the same situation, i beleive that a manual switch can be put into to play but not sure, maybe somebody can clear it up for us
Old Jun 1, 2006 | 12:11 PM
Shagwell's Avatar
Car: projects.......
do a search or read the tech article on how to manual lock-up the tc.
Old Jun 1, 2006 | 12:15 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
You can either use a toggle switch or an aftermarket setup that uses vac/speed.
If you can find an older canadian version of the car they were non CC and used a small vac switch mounted by the brake booster to operate the lockup.
In either case search it!
gta90
Sep 15, 2015 04:00 PM
beachrodder
Aug 25, 2015 08:05 AM
theurge
Aug 21, 2015 12:46 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
