locker for street?
Old May 31, 2006 | 10:14 AM
redbird8628's Avatar
Car: 1986 Firebird
Engine: 3.4 outa 95' bird
Axle/Gears: 3.42 open rear
locker for street?
i thought about how to get better traction as i have an open rear, i thought of getting a power tracs or detriot locker...does anybody have opinions on these or am i better off finding a posi rear from a T/A or somthing
Old May 31, 2006 | 10:38 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Best off with a limited slip. lockers are for loose dirt and straight line racing.
A locker or spool on the street will snap axles like twigs in corners.
Old May 31, 2006 | 12:11 PM
Shagwell's Avatar
Car: projects.......
unless you're going to upgrade axles and other hardware, don't try running a locker on the street. Stick with a posi/limited slip unit. - That said, I really like my True-trac.
Old May 31, 2006 | 06:43 PM
Car: 1986 Firebird
thanks, i figured a spool would break my axles, but wasnt sure about the locker, thanks for the input
Old May 31, 2006 | 06:59 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
All it takes is one time for that thing to stick locked when you pull a corner and you will be picking up your tire and axle out of someones front lawn!
Old May 31, 2006 | 07:07 PM
Chevyguy496's Avatar
Car: 86 Berlinetta
Engine: 454 coming eventually
Transmission: TH-400
Axle/Gears: 4 link and 9" coming eventually
locker
I run a Richmond lock-right in my IROC after I gernaded the stock gears/posi/bearings. I ran it for a summer and didn't have any problems. It makes the odd noise every once in awhile but from what I've seen thats how lockers are. It also makes a ratcheting noise when I turn and it unlocks, I don't mind. It hooks hard, it'll smoke both tires, and its never slipped or made any problems yet.
Old May 31, 2006 | 09:11 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i've run detriot lockers in my mudding trucks for years on the streets and had no issues whatsoever, the only problem is getting on the throttle in a turn will lock up the locker, but if you don't do that then you'll hear the faint sound of a rachet as you turn, but it's not that bad.
Old Jun 1, 2006 | 12:16 PM
Shagwell's Avatar
so have I, but that wasn't in a 26 or 28 spline 10-bolt either.....
cheesehomer
Dec 31, 2015 08:48 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
Nick McCardle
Sep 10, 2015 08:36 PM
