witch is better
Old May 25, 2006 | 08:22 PM
cyko83's Avatar
Car: 83 trans am
Engine: 5.7 V8
Transmission: 700R
witch is better
i have an 700R4 trans and i was woundering if the 700R4 trans any good againts a 400 or a 350turbo ??
Old May 25, 2006 | 08:23 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
How do you define "better"?
Old May 25, 2006 | 11:13 PM
Coach Hawk's Avatar
Car: 91' Pontiac Firebird
"Better" is relitive because it depens on what your looking for. In stock form, it is not stronger, but it has lockup and OD, so your milage and highway driving experience is better. It is lighter than a 400, so that could make it better. It can be bolted into an F-body using all factory parts and no real modifications, so that could make it better.
Old May 26, 2006 | 11:11 AM
cyko83's Avatar
Car: 83 trans am
Engine: 5.7 V8
Transmission: 700R
accel
does the 700r4 have better gear ratio then the 350 or 400 for quicker shifting ??
Old May 27, 2006 | 06:42 PM
Coach Hawk's Avatar
Gear ratios for those transmissions are as followes:
1st 2nd 3rd 4th Rev
700R4 3.06 1.62 1.00 0.70 2.29
TH350 2.52 1.52 1.00 1.93
TH400 2.48 1.48 1.00 2.00
Shifting isnt controlled by gear ratios though, shift timing, speed, firmness is all controled by the valve body.
inferno15
Aug 29, 2015 01:48 AM
trevor1010
Aug 26, 2015 02:41 PM
trevor1010
Aug 24, 2015 08:34 PM
camaro89rs355
Jul 24, 2002 09:40 PM
swisscheese
Jan 26, 2002 09:34 PM
