Going from 700r4 to 5spd
Old May 28, 2006 | 07:39 PM
IrocZ 888's Avatar
Hi All new here i have been a camaro freak for along time. But i have a few questions about switching from 700r4 to a 5 speed.
I got a camaro from the place i work and not sure whats in it. I belive it's an 85 Z28 that has the 5 speed that i want to switch to my 87 Iroc.
What im tryin to figure out is will it bolt up and what problems i will run into doing this swap. The other thing is, it has a new 350 block thats bored 30 over i want to swap also, but doing the trans first. So im not sure the trans is stock. I belive the 85's only came with 305's.
My Iroc is an 87 with a 350.
Old May 28, 2006 | 10:39 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
Yes the trans will bolt up to the motor but the flywheel is a different problem. As long as you get the all the hydraulics for the clutch and the crossmember, there should be no problem.
Old May 29, 2006 | 07:22 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
Do not be afraid to use the feature. Pages of info about auto to stick swaps.
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
