swapping T.C. without removing tranny
Old Jun 4, 2006 | 05:30 PM
r_wells1's Avatar
Car: 89 IROC
Engine: vortec head/ZZ4 cam/TPIed 350+.040
Axle/Gears: 3:27
Okay guys, Someplace on this message board I thought I saw a thread about swapping the torque converter without totally removing tranny. Something about installing LONG tranny/engine bolts and sliding the tranny back enough to remove and install a new converter. I've been search for a hour and have not been able to locate it.
Am I dreaming this up?
Old Jun 4, 2006 | 05:50 PM
camarokev400's Avatar
if you are going to go through trying to put longer bolts in it you pretty much have it out at that point, it is just as easy to drop the tranny down and get it the heck out of your way, i dont see it saving you any time...its kinda like the cut the hole if the floor to replace the fuel pump deal
Old Jun 4, 2006 | 07:00 PM
SebasIroc's Avatar
Car: Iroc-z 86
Engine: 350 4bbl
Transmission: built up 700r4
Axle/Gears: ls1 4.10 posi
come on it took me 45min to remove it while taking my time its a 3hour job at max if you do it on jack stand, remove/install.
Seb
Old Jun 4, 2006 | 10:47 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
haha, i figure its actually easier if its a driveway job to yank the motor.
If you got a hoist/forklift/couple of trees and some rope...
Just pull the motor out of the way, hop in and pull the TC.
For a driveway job i think that would be the easiest...
Old Jun 5, 2006 | 05:31 PM
Shagwell's Avatar
Car: projects.......
it wouldn't be possible to slide the trans back on longer bolts. Maybe in a truck, but our firewall wouldn't allow such a thing. Besides, as stated, at that point you already have the trans out, so you'd be doing more work than simply lowering it out and pulling the tc.
Old Jun 5, 2006 | 05:35 PM
1989iroc5.7's Avatar
Car: 89 iroc
Engine: 5.7
Axle/Gears: 3:73
JUST UNBOLT IT FROM THE ENGINE LEAVE CROSSMEMBER BOLTED TO TRANNY UNBOLTED FROM CAR LOWER IT DOWN ON A JACK AND SLIDE IT BACK A BIT THERE YOU GO.ITS EASY TO GET TO ALL THE TRANNY BOLTS WITH A VARY LONG EXTENSION AND A SWIVEL FROM AROUND THE REAR OF THE TRANNY.IVE PULLED THE TRANNIES IN MY IROC AND MY NATIONAL SEVERAL TIMES THIS WAY.THESE THINGS ARE EASY TO GET OUT,ITS LINEING THOSE DOWLE PINS BACK UP THATS ALITTLE HASSLE.
gta90
Sep 15, 2015 04:00 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
