Popping out of first gear with a T5
Old Jun 6, 2006 | 09:15 PM
1985WS6transam's Avatar
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
It seems as though this problem of mine is getting worse. When i got the car it never used to happen, now it happens everytime that i drive it. When i put the car into first gear, it will sometimes pop out of first even though it seems as though it was fully in gear. This doesnt happen with other gears, just first.
Whats going on here, anyone know??
Old Jun 6, 2006 | 09:23 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Ive had a few old trucks that did that because of low oil. might be worth a check...
But remember not to pull out the wrong plug or you'll be in for quite a repair!
Old Jun 7, 2006 | 12:33 PM
Shagwell's Avatar
Car: projects.......
.... a toasted syncro or slider....or possibly a worn shift fork/bushing that doesn't fully engage the slider even though the shift is.
Old Jun 19, 2006 | 03:17 AM
Pat Hall's Avatar
It could also be the small engagement teeth on first gear itself as well. If the teeth are excessively worn, it can cause the slider to pop off the gear under load.
db057
Apr 28, 2019 07:45 AM
Fronzizzle
Sep 8, 2015 12:10 PM
toyotekk
Sep 7, 2015 06:36 PM
toyotekk
Sep 6, 2015 02:21 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
