Stall Converters....
Old Jun 6, 2006 | 10:31 PM
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
Transmission: Built 700r4
i've searched.... but i cant get exactly what i'm looking for....
I need a 2500-3000rpm stall converter, that doens't lag the motor 1% at idle, but at its stall speed hits like a nuetral drop on a tranny. Or something similar.
My current 2200rpm stall is way too low for my cam, and is giving me a hard time.
Old Jun 7, 2006 | 12:26 PM
Shagwell's Avatar
Car: projects.......
No stall converters work this way. They'll all take off like a regular converter, only stall when "flashed" - meaning they only go to the stall rpm when you smack the throttle. The only way you get 0% at idle/stop and 100% at x-rpm is with a clutch. Even a trans brake creates some load, as you're still turning the pump and moving fluid.
- A higher stall will help idle surging and lag, but it'll still act like any other converter when put into gear or when you take of normal/easy.
darwinprice
17
Oct 11, 2015 11:51 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
lanceflame44
Sep 25, 2015 12:28 PM
amcnellis
Sep 16, 2015 04:16 PM
