HELP!!
Old Jun 10, 2006 | 11:44 AM
Big_C's Avatar
Car: 1989 Firebird
Engine: Custom 355 V8
Transmission: TH-350 with 3000 converter
HELP!!
Hey guys, I need some serious help. I have a 89 firebird that used to be a 2.8 v6, but I swaped that out for a custom 355 V8 pushing 400 horse. Behind that I have a B&M holeshot 3000 stall converter, and a fully rebuilt
th350 tranny. Ive put alot of time into this car and when I finally get it on the road my motor wont go over 3000 rpm when it is in gear. If it is in park it revs up no problem, but when I am driving on the street in any gear it wont go above 3000. I live on gravel roads and have an open rear end, so the wheels should be spinning out of control when I mash down on the gas, but they hardly break loose. I can't even to a burn out on any kind of pavement.
What do you guys think it is. I think it may be the converter. Any help would be great.
Old Jun 11, 2006 | 04:16 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
I think you are correct.
Old Jun 11, 2006 | 04:24 PM
matt_p's Avatar
Car: 1991 Z28
Transmission: WC T5
Axle/Gears: 3.73 Posi
Maybe its the knock sensor? Did you use one for the 350, or use your old 2.8 one. If you used the wrong one it would see knock when there really is none and pull timing like crazy.
Old Jun 11, 2006 | 06:45 PM
Shagwell's Avatar
Car: projects.......
...checked for vac leaks? Checked timing? Checked plugs(air fuel off)?
what ignition system are you running?
