Need transmissions models explained
Car: 91 Camaro RS Convertible
Hey all,
I have a 91 camaro rs. i want to install a 4th gen rear end with 3.73 gears. I will be putting in a 350 engine soon. I see all of these different models of trannys here on the board but I don't know what they are. Whould my stock auto tranny work with this setup or should I try to find a different tranny. I am looking to make 350 - 400 HP for street use. Let me know what you all think and thanks from a noob!!
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Is your current engine a v8? If so, your tranny will work - but don't be surprised if your 350's torque let's you know that your tranny needs a rebuild - my 305 ran my 700R4 tranny fine, no slippage - but when I put the 350 in front of it - a had major slippage, and had to get a rebuild done.
If you have v6 now - the tranny won't work, even though it's also a 700R4, it won't bolt up to a v8 block.
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
Car: 1992 RS
Engine: Carbed 350
Originally Posted by 84 Z-28 350
any chevy bellhousing/trans will bolt up to any chevy engine
Engine: 383
I beleve that is because of a clutch/flywheel issue....let me re-check things, but I've done it before whith TH-350's, so I know it works W/ autos
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Engine: 383 Carb
Transmission: 4L60
Originally Posted by drshirk
Can you guys tell me the different types of trannys. IE 700r4 ,th-350 etc and which years and which cars they come in? Thanks
The T10 4 speed manual was used in 1982 only. All manuals 83 and up are variants of the T5 5 speed manual.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
The '82 T10 is somewhat rare. The saginaw 4 speed is more common. Not that that really pertains to the queston on autos...
however, that leads me to ask; no third gens came with TH350s stock???
Engine: 383 Carb
Transmission: 4L60
Pac J
May 17, 2020 10:44 AM
