t56 bellhousing??
Car: 87iroc
Engine: 5.7vortecstealthram
Transmission: 5-speed
Axle/Gears: 9-bolt posi
t56 bellhousing??
Just a quick question about the bellhousing, it's off a 94 LT1 and I wanna swap it over to my 87 Iroc 5-speed. I have a vortec engine out of a 98 chev 1/2 ton and put the stealthram intake on it. So far the 5-speed is all right but I know it will tap out on me if I start flogging it . I'm just looking for some straight info regarding the swap. I can't find the right thread with the search feature. Thanx again for any info you guys might have
oh yeah, forgot to mention the 6-speed is off a 94 camaro roll-over. Its pretty cheap so I was going to pick it up and use it mainly for the tranny swap. Anyone need the engine? 120K and new optispark system
Last edited by stealthrocz; Jun 11, 2006 at 08:21 PM. Reason: Automerged Doublepost
Yes the bell housing will bolt to that motor.
Make sure you put a pilot bushing or bearing in the crank, otherwise you WILL destroy the transmission quickly.
bigjay89gta
Oct 15, 2015 08:04 AM
