Transmission mount
Old Jun 11, 2006 | 08:34 PM
84'Firebird's Avatar
Car: 84' Trans Am
Engine: 5.0 H.O. L69
Axle/Gears: 3.73 Disc Brakes
Transmission mount
I have a 1984 bird with a 2.8l and 700r4 trans, today i noticed the tranny mounts bad on it, how hard is this to replace?
Old Jun 11, 2006 | 08:45 PM
It's not
Old Jun 11, 2006 | 08:48 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
your in luck, tranny mounts are not hard to replace. Should take less than 20 minutes to do once your bird is on jacks. Use a jack to hold the tranny up then remove the 4 bolts on the tranny bar then unbolt the tranny mount.
Old Jun 11, 2006 | 08:50 PM
Car: 84' Trans Am
Thats cool, at first i thought it was the engine mounts but today i found out the tranny mount is the prob. is it possible to put it in without removing the crossmember bar?
Old Jun 12, 2006 | 08:21 PM
Car: 84' Trans Am
is it possible to not remove the crossmember and install the mount?
Old Jun 12, 2006 | 08:29 PM
88blkbird's Avatar
Car: 88 Firebird
Engine: 5.0 ltr
Transmission: 4L60
Axle/Gears: 10bolt 3.23's I think
Damned if I can remember for sure but I think it's possible, even if you need to remove the crossmember it's really only a twenty minute job
Old Jun 13, 2006 | 06:27 PM
86z/92rs's Avatar
You can try removing the bolt that holds the tranny mount to the cross member and jack the rear of the tranny up. You still need to get to the bolts that hold the rubber mount to the tranny itself. I've never personally done this route but it may work.
jhawkeye
May 25, 2022 06:33 PM
AussiePr0nCar
Mar 6, 2020 04:04 PM
Vintageracer
Jan 10, 2020 05:33 PM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
theshackle
Aug 23, 2015 03:49 PM
