I think I broke my rear end
Old Jun 12, 2006 | 12:59 AM
huntingwood's Avatar
Car: 1989 Trans Am
Engine: l98
Transmission: 700 R4
Axle/Gears: 10 bolt with 3.23s
I've had a annoying whining sound from the rear end (2.73s, posi, drums) for about a year now that only happens when I let off the gas. I posted about this awhile ago and was told it might be a pinion bearing. Well today I was driving and the whining suddenly got a whole lot louder and then turned to really loud grinding and clunking, so I pulled over. I was able to drive it home, and it seems perfectly normal still when I'm giving it gas, but as soon as I let off, it sounds like its chewing the gears to pieces.
I pretty much need the cheapest option right now, but if possible, I would like to upgrade and swap in a 3.42 or 3.23 rear end with disc brakes myself. Could anyone give me an approximate cost of finding one of these and doing the job? Or if anyone has had just the gears themselves replaced by a shop, I would like to know the cost of that also. Any suggestions for what I should do? Thanks!
Old Jun 12, 2006 | 09:11 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
You can probably swap in a used rear alot cheaper than having a new set installed mostly because of the labor.
If you get a whole rear you can put that in yourself in the driveway. since your making this post i doubt you have the skills or tools to properly install and lash a new set of gears, in which case your only option is a mechanic. can you say $cha ching$?!
Old Jun 12, 2006 | 03:17 PM
Car: 1989 Trans Am
Engine: l98
Where's the best place to find a used rearend? Ebay? Junkyard?
Old Jun 12, 2006 | 03:24 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
I think the 'best' would be the local JY. at least that way you know exactly what the condition is without any BS.
Also it costs a few bucks to ship around a rear end so i would leave ebay for last!
Old Jun 13, 2006 | 10:04 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
where are you located at? also, don't forget about the classifieds here. you can check them and see if there is anything for sale or post a wanted ad yourself.
Old Jun 15, 2006 | 06:22 PM
87IROCZ350TPI's Avatar
Car: 87 IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: BW 7.75" 3.27
I've seen a few posts for rears for sale over the last few days. They have ranged from $50 to $400. Just surf the site a little, I'm sure you'll find something.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
