how does it feel when you grenade your rear end ?
Car: 89 camaro rs
Engine: 2.8l V6
Transmission: auto
Axle/Gears: 10 bolt 3.42
I'd like to hear some stories of what actually happens when you "grenade"" your rear end. Mild stories to full-blown horror stories of axles shooting out the housing. I'd like to know what some of the symptoms are when you're about to grenade that 10-bolt ( so I'll know in time when to slow down
) thanks for sharing your adventures ...
) thanks for sharing your adventures ... Supreme Member
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
)haha, it will tell you when to slow down.
Most likely with the rear tires locking
Car: '82 Z28
Well, I can tell you what a powertrax no-slip locker feels like when it halfway goes out. You'll hear a bang then the car wants to pull to one side when you're on the gas. Mine locked open on the passenger side axle basicly making it a 1 wheel drive car. Friend of mine blew out a rear end and there was just a lot of clunking from the stripped gears inside. Car launched, ran through some water from a leaky fitting, the engine rpms went way up, caught traction and that's all she wrote.
Car: 92 RS Camaro
Engine: 305 TBI
i race a stock car here at a local track and blew up a rearend 2 weeks ago. coming out of turn three i got into it hard and the spider gear snapped. all i herd was a clunk and then the car go up to about 7000 grand. the axle came completly out of the housing still connected to the tire. then i took a nice little spin down the frontstrech.
edit turn 4
edit turn 4
Car: 89 camaro rs
Engine: 2.8l V6
Transmission: auto
Wow ! a lot of feedback already
keep those adventures coming guys, from the "oh, crap!" situations to the more bone-chilling moments
thanks for sharing !
thanks for sharing ! Joined: Mar 2003
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
From my personal experience and what I've read, when you start leaking out of the pinion seal is only a matter of time. It means the pinion bearing has too much play and then kaboom, followed by dead in the water.
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
here are 3 of the 13 pinions my brother broke over 3 years in his 96 LT1 6 speed with 280rwhp and 320rwtq.
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
"How does it feel when you grenade your rearend?"
Well sir, i feel a deep sense of accomplishment. it's gratifying really...lol!!!
my powertrax lockright locker was a loud clunk, pop and shake. it was pretty crazy. launched the car, spun hard and wheelhopped. thing didn't stand a chance:
the pinion gear was just a dull whine for a while, then i made 6 hard passes...the whine got really loud...then i spun the tires on the street once and it just started clunking really badly. took the cover off and found this:
Car: 87 IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: BW 7.75" 3.27
Originally Posted by mw66novathe pinion gear was just a dull whine for a while, then i made 6 hard passes...the whine got really loud...then i spun the tires on the street once and it just started clunking really badly. took the cover off and found this:
[IMG
[IMG
http://memimage.cardomain.net/member_images/5/web/437000-437999/437351_224_full.jpg[/IMG]
I've got a 9-bolt
Car: 90 IROC
Engine: 5.7 TPI
Transmission: auto 700-r4
AHH CRAP! lately.. i too have been hearing the whine get a little louder.. it was real quiet before but i hear it loudest when im on the freeway and i let off the gas completely.. you hear it go. voooooooo like a hummm and it gets quiter as the car loses momentum.. and it started getting louder after i did a few burnouts this past weekend and i just installed an aluminum DS.
crap.. how would i go about checking this out..
crap.. how would i go about checking this out.. Joined: Jun 2002
Engine: 7.0L
pull the diff cover and look for uneven wear in the gears. i have a "spare" rearend with the same ratio as what i run in my "good" rearend. the spare whines ALOT. so much that i used the pitch of the whine as a cruise control since my car doesn't have a real cruise control, lol! anyhow, when i pulled the rearend out to put the good one back in(fresh rebuild with good used factory gears and a solid pinion spacer WOOHOO!) i noticed alot of uneven wear on the gears. it'll endup needing a rebuild shortly...
Car: 86 camaro sport coupe
Engine: 355
When the 10 bolt in my S10 went it was a loud crack and immediate loss of acceleration. That was when the pinion shaft broke, and I learned how bad wheel hop can be.
Car: 86 Camaro
Engine: none
Transmission: none
Axle/Gears: GT4, 3:73s
crap.. how would i go about checking this out..ive broken a couple rear ends, one under hard acceleration and the other launching.
....I'd like to know what some of the symptoms are when you're about to grenade that 10-bolt ( so I'll know in time when to slow down)
Car: 89 camaro rs
Engine: 2.8l V6
Transmission: auto
Wow , allright !
we're getting some cool pics and even cooler stories
So far we dont have anyone who sustained personal injuries ???
Keep sharing guys ...
Keep sharing guys ... Member
Car: 86 Omni GLHT
Engine: 2.2 Turbo/Intercooled
Transmission: 5 speed
Axle/Gears: 3:85
racing on highway and took off fine then about 80 or so i hear boom boom in the rear thought i broke the driveshaft... no cracked the ring gear in half and knocked some teeth off the pinion gear....
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
If you are doing a burnout... and the burnout suddenly stops, thats a BIG hint right there. If you have a manual trans, and you can throw it in first w/o using the clutch, when the engine is running, and you don't go anywhere - thats also a BIG hint.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
novaderrik
Aug 10, 2015 12:44 PM
