Quote:
read that mines the rear drum brakes i will try and do the jack stand theory just gotta find someone to put it in gear and keep it started due to it being a manual transmissionOriginally Posted by big gear head
Did you read this? https://www.thirdgen.org/forums/tran...ing-axles.html Supreme Member
Disc brakes or drum brakes, makes no difference. Once the brake drum or rotor is removed everything esle is the same.
if i kick my tire and get a loud pinging noise its the axel shaft right?
You do not need to have someone keep it in gear while you watch...all you need to do is put it in gear and rev it up then put it in nuetral and get out and watch the wheel spin...
If you have a wobble then it is the axle shaft and it will need replacing. Keep in mind that when you have the car up on jackstands that you should not have any movement of the axle shaft, rotating the wheel forward and backward should give you an idea of grinding/drag and you should be listening too.
Fivestar
Fivestar
i dont see a wobble but it does move when i push/pull on wheels on both sides
A little in and out movement is normal for a c clip axle. If it has an Auburn differential then the axle end play will increase as the cones in the differential wear.
not sure what kind of diff i have but i orderd new axel shaft for the passenger side
Why did you order a new axle? Is yours bent or worn where the axle bearing runs on it?
When you remove the cover you will be able to tell which differential you have.
The passenger side is bent from falling off jackOriginally Posted by big gear head
Why did you order a new axle? Is yours bent or worn where the axle bearing runs on it? When you remove the cover you will be able to tell which differential you have.
sofakingdom
close
- Join DateSep 2005
- iTrader Positive Feedback100
- iTrader Feedback Score(1)
- CarYes
- EngineUsually
- TransmissionSometimes
- Axle/GearsBehind me somewhere
- Liked:2,485 Times in 1,897 Posts
Ouch...
Some questions seem better left unasked, once you have the answer. Too bad there's no way to know that in advance.
Yep let's just say crappy original jack.. got all new creeper set from auto zone $70 so mistake learned from lolOriginally Posted by sofakingdom
Ouch...Some questions seem better left unasked, once you have the answer. Too bad there's no way to know that in advance.
