need speedo help please
Old Jun 13, 2006 | 10:48 PM
trans1973's Avatar
Car: 88 Tran Am
Engine: 350 tbi
Axle/Gears: 9 bolt, 327 gears
just put a different t5 in my 88 trans am. the old tranny has a vss, the new one was set up with a cable. i was told i could put the vss in the older tranny and it would work, well, it didnt. how do i get my speedo working? i know the speedo is fine, and i know the vss is fine. thanks for any help
Old Jun 14, 2006 | 11:45 AM
ttypecamaro's Avatar
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
did it bolt up fine? I put a VSS in a cable driven t5 from an 88 camaro. you might want to try using the gear off of the cable setup and put it on your VSS, maybe they're not meshing properly inside.
Old Jun 14, 2006 | 08:43 PM
trans1973's Avatar
Car: 88 Tran Am
Engine: 350 tbi
yeah, it bolted up fine. ill try the other gear though, good idea. thanks man
GTAman
Jul 3, 2024 07:29 PM
Elephantismo
Feb 13, 2019 12:51 AM
Nervous2
Oct 8, 2015 10:53 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
TrevinE
Sep 14, 2015 03:20 PM
