lock up help
Old Jun 14, 2006 | 01:08 AM
Bobbyz's Avatar
Car: 87 IROC Z "ZZ4"
Engine: 350 "ZZ4"
Transmission: ck performance th400 3000 stall
Axle/Gears: 3:73 10 bolt
lock up help
Ok i know this has been beaten to death on here and i did search but i still need some help.
i went to carb on my car and tossed the computer and harnesses and now i need the trans to lock up, so from what i gathered on here is i ran the purple wire from the trans connector to a 12 volt switch power and the tan/black to a switch and then added another wire from the switch to a ground.
i took the car out and flipped the switch when i was cruiseing in fourth and felt nothing. i played with the switch flipping it on and off driving stopping everything and felt nada. i read on here that the car would bogg down or the rpms would drop some if it was working.
also this is the 2nd trans i put in and i tried it with the first trans and nada same with the 2nd trans nada
do i have this think hooked up right?
i plan on getting the painless lock up kit but i was looking for something to work for now.
thanks
Old Jun 14, 2006 | 01:10 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
If the lockup is functioning you will see a few hundred RPM decrease at cruise and it will stall the motor if you stop with it locked.
The original harness in my car had a single green wire...
jrdturbo
Mar 31, 2016 02:58 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
kkirch15
Sep 30, 2015 04:44 PM
Damon
Sep 26, 2015 04:29 PM
Dragonsys
Sep 25, 2015 03:51 PM
