driveshaft lenth
Car: 1982 z28
Transmission: th350
driveshaft lenth
got a 82 z28 new tranny w/ 9 in. tail shaft, just did a swap 305 for a 350, is there a standardized lenth i need to reduce from the drive shaft or do i need to do the math myself (not recommended
i gotta do that and figure out what i gotta do for this crossmember issue. seems it lines up lenth wise, but seems to not line up otherwise. the new tranny has 2 boltholes instead of one, and im assuming forceing this to line up isnt right ,a little help? thankz,mark
i gotta do that and figure out what i gotta do for this crossmember issue. seems it lines up lenth wise, but seems to not line up otherwise. the new tranny has 2 boltholes instead of one, and im assuming forceing this to line up isnt right ,a little help? thankz,mark Joined: Sep 2005
Not sure about the drive shaft length....
However, ALL transmissions have 2 bolt holes for the mount; and ALL crossmembers have 1 bolt hole. Sounds to me like you're trying to put it together without a mount. That won't work.
Car: 1982 z28
Transmission: th350
im not very knowledgable in the tech. deal here, i did everything up to this point perfect with the help of this site , ya ive got a crossmember and again im tryin to figure out what to do on aligning the hole or holes, because as as it is i can only do this by forcing something, and that may be proper since ive changed motors and transmissions,
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
topteam54
Oct 6, 2015 12:21 AM
