toqueconverter loose?
Old Jun 14, 2006 | 06:52 AM
ricktaylor's Avatar
Car: 84z28
Engine: 305h.o. mild mod's
Transmission: 700r4 shiftkit
Havent checked yet but it almost sounds like the exhaust is hitting under the tunnel but its not, could it possibly be a loose converter? Car shifts fine.
Old Jun 14, 2006 | 07:09 AM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Could possibly be a torque convertor bolt has worked loose and hitting something.
Typically when convertors go south they squeel and screech like a stuck pig, they dont tick like lifters.
Old Jun 14, 2006 | 10:07 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
If the bolts worked loose they can make some ticking or banging. Its not too hard to check, pull the 4 bolts on the cover and check the 3 bolts on the TC
Old Jun 14, 2006 | 01:43 PM
ricktaylor's Avatar
Car: 84z28
thanks for gettin back.
appreciate you guy's feed back, helps alot, will check this wekend when I get outta this Semi.
83 Crossfire TA
Jan 3, 2016 01:26 PM
92camaro350cci
Oct 14, 2015 09:29 AM
budowski
Carburetors
Oct 2, 2015 10:16 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
reactor60
Sep 22, 2015 01:44 PM
