transmission lines.
Old Jun 14, 2006 | 06:56 AM
ricktaylor's Avatar
Car: 84z28
Engine: 305h.o. mild mod's
Transmission: 700r4 shiftkit
transmission lines.
anybody do away with their factory lines from tranny to cooler and if so what are you using in place of them?
Old Jun 14, 2006 | 07:07 AM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
yep. and -8 lines make for an easy install with no leaks...just pricey. Like anything else though you usually get what you pay for.
Old Jun 14, 2006 | 10:08 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Yep, i run aeroquip hydraulic hose on mine. works good...
Old Jun 14, 2006 | 08:14 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
do you guys have any pics of the fittings going into the trans for the SS braided lines?
We had to use the stock metal line for a short run from the trans then to braided lines since it was really really tight to get the fittings and the SS lines up and next to the trans.
Old Jun 14, 2006 | 08:21 PM
IHI's Avatar
IHI
I dont have any pictures and am running a TH400 so it might be a little different, but there is ample room for my -8 fittings and I can even get a wrench on them with a little angle to tighten/loosen with no fuss.
pjsparts
Oct 29, 2025 06:39 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
