weird slight jerking/clunk feel from RE
Old Jun 14, 2006 | 01:57 PM
FireBirdKnight's Avatar
Car: 1985 TransAm
Engine: 5.0L TPI
Transmission: 700R4 auto
Axle/Gears: 3.27 BorgWarner
when im at a stop if i give the car heavy pedal but not flooring it.. it will make a very slight jerk/clunk feel from the rear-end its not audiable nor effects driveability but i can feel it
ive heard that a slight jerk/clunk is normal
had u-joints inspected and are in good condition trans-mount is also new
diffrential fluid level is full
could it be a DIFFRENTIAL problem occuring or is it just normal operation
cuz at normal pedaling it doesnt do it
help!
Old Jun 15, 2006 | 02:36 AM
86irocterror's Avatar
i would begin by looking at all your rear bushings in the suspension, the control arm bushings, panhard bar bushings and sway bar bushings. it is possible there is wear in your rear end and that can cause some noise and such under heavy loads, but its a good idea to start with the cheaper and easier stuff just to eliminate them if the bushings arent the problem.
Old Jun 15, 2006 | 09:20 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
How 'new' is the trans mount?
They dont last very long if you drive hard!
gta892000
Aug 11, 2019 11:16 AM
92-Formula
Dec 12, 2015 10:34 PM
Antips16
Oct 30, 2015 06:42 PM
xbazzarex
Exterior Parts for Sale
16
Oct 6, 2015 08:42 PM
Marc Brown
Fabrication
17
Sep 25, 2015 03:43 PM
