undercar DVR side makes a clunk that can be felt what could it be?
Car: 1985 TransAm
Engine: 5.0L TPI
Transmission: 700R4 auto
Axle/Gears: 3.27 BorgWarner
during acceleration only from a stop i get a small clunk from under where i sit..
my guess its the trans-mount...
suggestions??
suggestions??
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
trans mount...
Get a floor jack and jact up on the tailshaft of the trans, you will most likely find that it lifts off of the x-member.
Car: 1985 TransAm
Engine: 5.0L TPI
i looked at the trans mount it only has a slight tear in it
it looks like this [V] thats the design of the mount it doesnt look like that V in the middle is a tear just design but should it be solid? [ ]
but can u push on the trans by hand to see if it will move? or have to use a jack? it didnt really seem to even budge by hand i guess its time to switch to a poly-type mount for the hell of it... **** stupid rubbers only good for not having unwanted kids not preformance parts lol....
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
well it depends how strong you are and if your gut isnt too big that you cant get under the car!
Personally i am able to move mine when it breaks, but then again im not quite a 50lb weakling either. Remember when your lifting the back of the motor too.
For the sake of not ripping yourself a new **** hole just use a jack!
Car: 1985 TransAm
Engine: 5.0L TPI
i checked the mount its tight & uncracked
i narrowed the noise down its comming from the front end somwhere in the middle well im basing the facts from the noise / clunk i heard was around the center consoul prob looking at a suspension issue?
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
apparently bad u-joints can cause a clunk when going into power.
how's your TA mount?
Car: 1985 TransAm
Engine: 5.0L TPI
symptoms:
checked trans mount =ok
checked rear end and diffrential gears = ok
checked front susp = ok
checked u-joints = tight and greased = ok
checked sway bar = ok
checked torque arm = questionable unknown results???
checked rubber bushings = some showing age but not damaged = ok
Torque arm bushings worn from years of work and abuse ?????
car only "clunks" on heavy to moderate accel from dead stop or in reverse giving it a good GO it will make a loud clunk
car doesnt clunk while turning , driving accel or decel , braking
car does not "clunk" when shifting from P to R or D
checked trans mount
theshackle
Sep 17, 2020 08:26 AM
