WOT Shift Help
Old Jun 16, 2006 | 03:40 PM
InsaneIROC's Avatar
Car: 89 1LE IROC Z28
Engine: 364 Ci Ls2
Transmission: Mn12 T56
Axle/Gears: Borg Warner 9 Bolt With 3.70 Gears
WOT Shift Help
Has anyone used the TransGO 7004th Shift Valve Kit part # 7-4-valve. I had one installed in my trans and it wont shift into OD at WOT. Can some one help me.
Old Jun 16, 2006 | 06:27 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
What year is your trans?
I see your cars an 89 and the valve is only supposed to be good for 82-88...
Old Jun 17, 2006 | 12:36 PM
InsaneIROC's Avatar
Engine: 364 Ci Ls2
The trans is a 89
Old Jun 18, 2006 | 12:20 AM
86_Dan_Z28's Avatar
Car: 86 Z28
How old is your trans? The clutches or band may be slipping.
Old Jun 18, 2006 | 01:05 AM
InsaneIROC's Avatar
Engine: 364 Ci Ls2
The Motor Trans and Rear all have 4000 miles on them when I had the trans built they used all the best parts thay said it would hold up to 600 HP.
Old Jul 4, 2006 | 12:04 AM
88IROCZZ4's Avatar
Car: 1985 Z28 Coupe
Engine: Carb'd LB9 .030 over
Transmission: TH700R4
Axle/Gears: Posi 3.42 10-bolt
from my experience the 700r4 wil not shift into OD at WOT unless you let off a bit ... try letting off to about 3/4 throttle and see if it shifts into OD.
Old Jul 4, 2006 | 12:20 AM
InsaneIROC's Avatar
Engine: 364 Ci Ls2
I had it built so it would shift at WOT like the Vette's and Police Interceptor's
Pac J
May 17, 2020 10:44 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
racereese
Oct 3, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Damon
Sep 26, 2015 04:29 PM
