700r4 won't shift
Old Jun 19, 2006 | 09:39 PM
kbugjrabbit's Avatar
Car: 1986Camaro
Engine: carb350
700r4 won't shift
OK, I know this question has been covered a billion times and I have done a search only not to find the answer I think I need. Heres the deal. 1986 Camaro V6 700r4. Removed V6 and put in a carbed 350 and got the Bowtie Overdrive wiring kit to eliminate computer stuff for tranny. Adjusted T.V. cable as per instructions thru B.O. I have no tach so shift points are unknown. When I drive the car(normally) down the road all seems well. My problem occurs when I power brake the car. After releasing the brake and taking off,the tranny will not shift. Now,I like to shift the car so I have it in low and manually shift up. Obviously I don't have something right but what? Now you might ask what happens when I power brake with the tranny in drive? Well it shifts but to quickly. Won't let the motor build any steam. This motor is no powerhouse and carries a basic 350 c.i.d. power but is no slouch.
Thanks for any help and sorry for the repeat question,I really did search it.
Old Jun 19, 2006 | 10:29 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
How did you mount a V6 tranny to a V8 block?
Old Jun 20, 2006 | 07:35 PM
Car: 1986Camaro
Engine: carb350
My bad, had a V8 donor car. Got the tranny,harness and such from it.
Hotrodboba400
Dec 10, 2019 07:07 PM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TheTraut88
Sep 7, 2015 05:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
