deep pans
Old Jun 20, 2006 | 12:14 PM
thirdgenlover's Avatar
Car: 87 trans am
Engine: 350 TPI bored .040 over
Transmission: modified 700r4
Axle/Gears: stock spline, 3.73 Eaton posi
deep pans
when you put a shift kit in, and raise the pressure of the regular, when is it necessory to get a deeper pan
Old Jun 20, 2006 | 12:43 PM
Shagwell's Avatar
Car: projects.......
a deeper pan is added simply for more fluid. More fluid allows for better heat disipation, lowering trans temps.
Needing a deeper pan isn't because of a shift kit.
Old Jun 20, 2006 | 01:11 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
The deeper pan is for extra cooling capacity from the extra fluid.
Im not too sure if you would want to go with a deep pan, might end up dragging it on a speedbump or something!
Maybe someone here runs one and can fill you in on what clearance is like...
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
