govener reweight question
Old Jun 22, 2006 | 12:00 AM
Luther6704's Avatar
Car: 1986 Iroc
Engine: 305 TPI w/30,000 original miles
Transmission: 700r4 Transgo Shift Kit
after rebuilding my trans with a shift kit, the car will shift too early (around 3500 - 4000rpm) the local trans guy said to put a sinker weight on the end of the detent cable, but i dont think that the cable is stretched since the car has low mileage. the cable does however pull allmost the whole way through the detent cable adjuster. I heard somewhere that since the shift kit has more line pressure that i need to reweight the govener to get it to shift right. Any insight?
Old Jun 23, 2006 | 05:35 AM
Pro Built Automatics's Avatar
If you have the TV cable set to where it is tight at WOT, and the shifts are still low at WOT, then you need a lighter weight governor to get the shifts at WOT higher. You can by the weights kit from B&M and do the changes to get the shifts at the rpm you want at WOT. It will take some work, but it can be done.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
