700r4 shifts out of 1st automaticaly
Old Jul 10, 2006 | 07:43 AM
graphicideas1's Avatar
My 700r4 shifts out of 1st even if i try to hold it into 1st gear manually - is that correct?
Old Jul 10, 2006 | 10:34 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Yes.
RBob.
Old Jul 10, 2006 | 10:36 AM
any way to stop that from happening? what controlls that the computer?
Old Jul 10, 2006 | 10:49 AM
Green89IROC305's Avatar
Car: 91 Z28 - using 87 electricals
Engine: 383 HSR EBL
Transmission: 700R4 - Stage 3 Fixed Pressure
Axle/Gears: GM 3.08 POSI
its designed to do that. i believe the govenor and another of the transmission componants are responsible for this. so no you cant easily change this. also the computer has no contro over the transmissions in our cars they are controlled by a TV cable. on another note be glad that your transmission does this. the one in my 91 rs didnt and i accidently downshifted manually to 1st instead of second and i blew out second reverse and 4th gear. 3rd gear went out shortly thereafter.
i believe that teh transmission is designe to shift out of 1st at 38 mph regardless of shifter selection(assuming the regulation is working taht is). its better for your trans.
Old Jul 10, 2006 | 11:47 AM
thirdgenlover's Avatar
Car: 87 trans am
Engine: 350 TPI bored .040 over
Transmission: modified 700r4
Axle/Gears: stock spline, 3.73 Eaton posi
put a corvette governor in there, that will get you higher than 5000 rpm, but yeah its a safety feature
Old Jul 10, 2006 | 12:25 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Installing a TransGo shift kit eliminates that behavior.
Old Jul 11, 2006 | 09:06 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
In agreement, it will need to be the re-programming kit (not the Jr Shift kit).
RBob.
Old Jul 11, 2006 | 04:56 PM
Car: 87 trans am
re programming kit? how
Old Jul 11, 2006 | 06:07 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
RBob.
Right, either the retail kit or the 700-2&3 reprogramming kit, not the 700 SK or 700SK Jr.
Old Jul 11, 2006 | 06:36 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Changes oil pasages in the valve body to give it different shifting characteristics.
Thieirs gotta be 50 things you can do on these to change shifting!
junior419
Apr 7, 2025 11:35 AM
indygene
Sep 26, 2015 11:21 AM
Dragonsys
Sep 25, 2015 03:51 PM
6998poncho
Sep 25, 2015 02:56 PM
