tranny problem help please!
Old Jul 13, 2006 | 04:13 PM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
could anybody help me.....i have a 89 formula 350 with 700r4 tranny. i havent done a thing to the tranny no shift kit nothing....but it is rebuilt....twice actually anyways....when i first got the car it shifted from first when cruising at around 1700ish rpms a smooth shift now its shifting at 2500 and if i try to manumatic it it wont shift into a higher gear...another problem with it is that when i raced it before i put it in drive and powerbrake to 1200 rpms dumped the brake and floored it. worked well......well i tried doing that again and it is shifting at 3000rpms when i floor it....missing 1500 rpms of power.....whats wong with it and how can i fix it?
Old Jul 14, 2006 | 02:04 PM
Shagwell's Avatar
Car: projects.......
Check the adjustment of your detent cable(do a search, it's been posted many times). If it's correct, then drop the pan and check to see if the detent valve is sliding properly.
- Pull the governor, remove the gear(make sure it's in good shape) and pull the "apple core" and clean everything thoroughly.
Old Jul 14, 2006 | 09:56 PM
Car: 92 Camaro
Axle/Gears: S60 373
much thanks....would a shift kit make it worse??
Old Jul 14, 2006 | 10:21 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
Well if it is the detent cable you should tet it fixed. You can burn up a trany if it issent set right. A shift kit should make the clutches last longer because there isent as much slipping between shifts.
Old Jul 14, 2006 | 10:31 PM
Car: 92 Camaro
Axle/Gears: S60 373
alright thanks guys much appreciated....
Old Jul 15, 2006 | 02:32 PM
Car: 92 Camaro
Axle/Gears: S60 373
what is the apple core??
greenyone
Sep 2, 2015 03:39 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
spaigo
Aug 21, 2015 07:46 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
