2.73 = Why Bother, I'll Lose?
Old Jul 22, 2006 | 06:44 PM
3rdGenThrowdown's Avatar
Car: 1986 Camaro Sport Coupe-totaled :_(
Engine: LG4 V8 (alive! HAHAHA!)
Transmission: automatic 4(alive-ish I think)
Axle/Gears: 2.73, stock (dead, most likely)
I'm sure this has been done; and over done, but I'm looking for suggestions as to what gears give pretty much all around performance, as well as manageable gas mileage. Right now I have the stock 2.73's and want something that will allow better 0-60 times as well as better 0-80 acceleration. Any ideas?
Old Jul 22, 2006 | 07:31 PM
jr. gearhead's Avatar
Car: 83 T-Top w/ 85 Z-28 and 91 RS parts
Engine: 377 (in progress)
Transmission: 700-R4 (unless i find a t-56)
Axle/Gears: from the Z
well, gears are a direct link in the balance between ecomomy vs. performance. what you need to find is the balance between where you are (2.73) and what is generally considered the max for street vehicles (4.11). the 3.42's that were optionial in some iroc's and g92's are a good middle ground. personally a better option is a set of 3.73's. use the tech calculators and plug in the different options for gears and see what effect it will have on the rpms vs. speed. the economy will go down as the gear ratio goes up, but not linearly. reason for this is that the higher gears actually make it easier for the engine to move the car...like downshifting does. this only goes so far, because it takes more throttle to keep the rpm's up. the gear change will also affect your speedometer as well. be happy to explain more if you have any other ?'s.
Old Jul 22, 2006 | 09:30 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
3.42's are great for daily drivers.
Old Jul 22, 2006 | 09:36 PM
gray89vert's Avatar
Car: 1989 RS convertible
Engine: 305 TBI LO3
Transmission: TH-700-R4
Axle/Gears: stock axles 3.73 LSD
3.23's or 3.42's even 3.73's are ok but not if u want top speed
Old Jul 22, 2006 | 09:47 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
3.42 are perfect imo
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
z28joe2
Sep 28, 2015 05:54 PM
3.8TransAM
Sep 27, 2015 08:37 PM
Stryker412
Sep 20, 2015 06:59 PM
64Chief
Sep 12, 2015 08:05 AM
